Charles Morgan
- Feb 2, 2010
- Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
Plan of attack is to check the compression on the existing engine and if good, put that in (after mounting CPS on back plate). If not good, we will rebuild head I had refurbed (or use bits to help). We'll do compression check using starter motor.
Finish off suspension work (drop links and ARBs at rear), fit driveshafts, refit propshaft and box (after a small overhaul), overhaul and fit new bits to fuel system, then drop engine in when above work done. Do whatever work required to fuel rail (at machine shop).
