Thejestersshoes said:
1/The icons around the top of the headlamp switch are not illuminated(very surprising as you cant see where the switch position is at night)
I have an older W210 E240, and I'm sure the headlamp switch (without venturing out into the garage) are illuminated
2/There appears to be only one rear fog lamp-has a bulb blown?-I cant belive MB only fit one!
Yeah same here, though 'I think' that may be British Standards? Two might appear to be brake lights. (i.e. car looks like it's braking)
3/Rain sensing wipers are useless - spend more time fiddling with the wiper switch
Mine are very slow to react at times (too much droplet build up), though I had a C class courtesy car and that seemed to have improved sensitivity, and worked fine. Your E class is newer than the C.
4/I'm really surprised at how much engine noise you get inside the car under moderate acceleration.
I get a surprising amount of noise when the engine is cold, but goes away when warm.
5/The heated seats are not warm enough! (compared to previous cars anyway)
I don't have heated seats, so can't comment. A C class I tried seemed to be OK, though not hot, but then it wasn't a very cold morning.
6/The CD changer is really slow changing from one CD to another (standard MB 6cd in dash)
Yeah, it is a bit slow
7/The air con is weak for a car of this size & quality
I'm convinced the UK market (all makes of car) get a less powerful version than tropical climates, - unless aircon isn't as effective in the dry heat (radiated heat) of the UK, to more humid climates (which contain the heat in the moist air).
8/The folding mirrors should(in my view) automatically fold out when you drive away
That wouldn't work for me, as I fold the mirrors to get into my garage to limit the risk of scraping them on the sides. Though there perhaps should be a switch to engage or disengage the function, like the nearside dipping mirror on reverse gear.
