spraydizzy
- Feb 8, 2012
How much metal did you remove when you recut the seats, you are only meant to clean the carbon off and and stop as soon as you see the first signs of alloy. If you have removed too much you will probably find that you would need 2 to washers as the clamp would not be able to pull the injector down tight enough to stop it leaking.
If there are signs of coolant then you might have pierced the water way under the bolts. Fitting 2 washers will not cause it to smoke, i have had to do that before as a stop gap while waiting for a new head and it didn't cause any smoking or make any difference to how the engine ran, you are only talking of raising the injector by a few thou. I would tend more towards it been some crap stuck in one of the injectors from when you removed them.
Martin
Hi Martin
Now you mention it I don't think i used the seating tool enough as i didn't want to remove too much material, I just removed the carbon and stopped.
I had all the injectors professorially cleaned and checked prior to fitting can the extra washers be causing the smoke by the now incorrect positioning ?
is the water jacket the head gasket? and if its now damaged what problem dose it cause?
Panason1c has said the injectors should not have two washers
