Ordered some rear brake pads off EuroCarParts in May, went to get them fitted today and the bloke said they're the wrong type...
ECP didn't send what I ordered - I ended up with some Textar ones for a W124 (not sure if they would have fitted) but I suspect it might just be a difference between 1 or 2 retaining pins?
I'm not in a great hurry to take the wheels off and check, can I tell from my VIN what type I need?
On Detaili it's showing an option for either one or two pins:
http://www.detali.ru/cat/oem_mb2.asp?TP=1&F=202078&M=111921&GA=722603&VIN=&CT=F&cat=45H&SID=42&SGR=045&SGN=02
with the deciding factor being the numbers after the F in my VIN but mine don't appear in the list!
You'll see on the ECP link there's loads of different types, what do I need?!
It's a May 1997 C180 estate...
