KettleDrum
- Jul 24, 2014
- 2005 C-Class Coupe (W203)
Hi Guys,
My first post on here, just trying to get some insight from someone in the know.
I have a 2005 C-Class C220 CDI Coupe (W203). Car runs great and its a pleasure to drive (especially over longer distances) but I've had tons of minor issues with it over the last month or two (perhaps it's just the age showing).
The latest is the following: a few days ago I noticed the the car won't lock/unlock at a distance with the fob. At the same time I've noticed that I have virtually no radio reception. After trawling the forums I figured it's an issue with the RF Aerial Amplifier. I double checked fuse #8 and this is fine. I also replaced batteries in both fobs (tested both primary and spare) just in case. The car also locks/unlocks from inside using the button on the dash.
I've taken the car in to an independent MB garage and they confirmed that the Antenna Amplifier needs to be replaced. So far so good, however my issues are the following:
1 - Assuming it's an antenna amp fault, the IR locking/unlocking method (in the driver-side door handle) should be working, correct? The problem is it's intermittent - I have to try quite a few times to get it to work. I mentioned this to my mechanic and he mentioned that this is "part of the same system" and this is why it doesn't work. Is this correct? Why have a secondary system (IR) if it still relies on the RF antenna amp? Could someone please confirm that this should work and is independent? If so what could be the reason for the intermittent locking/unlocking? A faulty (or failing) IR sensor? Worn wiring in the door?
2 - The cost the mechanic has quoted me on the repair seems ridiculously high - upwards of £700 broken down as:
£330 for parts (I'm assuming for the amp and 2 seals needed)
Does anyone know the part numbers for the amp and 2 seals?
£225 for labour
£150 for the "specialist" company to remove the back window from the car
This doesn't cover the cost of the back window should it need to be replaced if it gets broken during the removal (apparently this happens
), which is £180
To all the experts on here, do these prices seem normal to you? Potentially almost £1000 to fix a "nice to have" feature on a car worth £6000? Seems ridiculous.
I'm based in London but am willing to travel some ways to get it repaired for a reasonable price (at least the IR element, if not the entire thing).
If anyone can provide any help or advice on the above, I'd be extremely grateful!
Thanks in advance!
£225 for labour
Thanks in advance!
