Paddle Shifters... Thoughts?
If you use the paddles all the time, it becomes second nature knowing what gear you're in.
I love the paddles.
Used them ever since I got the car.
Wouldn't drive without them, apart from when using "C" when I first start the car, until the drive train is warm.
There seems to be aspects of the paddles that people either dismiss or chose to ignore..
1) Paddles change the gears faster than you could ever change gear with a manual gearbox.
2) The paddles encourage you to keep both hands on the wheel at ALL times, making it a much more safer and efficient way of changing gear.
3) by using the paddles, you can utilise engine breaking, allowing you to slow the car by using the gears and the brakes - thus SAVING YOU MONEY in the long run.
4) you can prep the car/ gearbox prior to entering a corner.
5) you can hold gears, which is very helpful when tentatively engaging in an overtake even when going on and coming off the gas. Whereas in auto mode, you may find the gearbox changes up when you don't want it to when you slightly lift off the gas momentarily.
6) you can really hear the orchestra of sound by holding gears. You can climb revs slowly under partial load or rip through the rev range at full load.. All while holding a gear. Equally, you can hear the glorious sound of the engine and exhaust as you let of the gas and let the revs fall gradually.. hearing the crackles, pops and booms from the exhaust.
7) by using the paddles, you can be more involved in the drive, rather than sitting there as a passenger while the car does everything. It's great in traffic I guess, but not when you up and moving, surely?!
Ok, number 6 is more for the AMG's, but you get what I mean.
All I'm saying is that there is much fun and many benefits to using the paddles.
The thing everyone gets hung up on is the slight delay between flicking a paddle and the gear changing.
This delay seems to be more pronounced in non AMG cars.
My dad's E350, for example, has paddles and the delay after flicking the paddles in that are more pronounced that mine.
But as mentioned, you can adapt your driving to "time" your gear changes.
You really can.
I never used to use the tiptronic in my old W208 because that really was a lazy ass gearbox and it was usually more trouble than it was worth.
But I love the paddles in my 63 and would never drive without them.
Paddles all the way for me! :rock:
I use my paddles a lot to drop a gear or two when in s+ mode but only really use M and paddles on the track.
I also use my paddles a lot , been used to them as I've had them for years now , and there pretty awesome part of the driving experience , wouldn't be without them now ,
They also change gear more responsive than driving with the auto and kick down ,,,
Try and get used to them ;)
Arhh! that's bloody cheating Justin! no wonder your giving me a whooping at GW :D I will have to get the Rash manual gear shift mode book out, and read it indepth:p
Rash's first hand teaching lessons at GW have not worked on me, but he did do his best!:D I' m a slow learner!
ricky s said:
Arhh! that's bloody cheating Justin! no wonder your giving me a whooping at GW :D I will have to get the Rash manual gear shift mode book out, and read it indepth:p Rash's first hand teaching lessons at GW have not worked on me, but he did do his best!:D I' m a slow learner!
Your to modest Ricky, but I must admit I does get a bit much for me some times, it just happens to quickly and I sometimes just slam into the limiter!! Perhaps we need the Rashman sitting next to us shouting change, changes furlking change.... :-)
Paddle shifter all day long....it's like most things, once you get used to it, it becomes second nature
Oh!:rolleyes: Chris, mate, jez, don't you start muddying the waters down the south mate, manual, manual, jez it will be emperor Rashman soon, all hail manual Rash!!! I like auto!, with a tiny bit of down shifting now and then when the likes of Simon M, Justin, Sean, and a few others are upon me at GW track days, giving me a whooping, great fun though! :thumb:Auto all day long for me!, however, might be a game plan for Vmax though:p really looking forward to that day, there's a few of us going, and again it's going to be fun, look forward to a chat.:thumb:
In my SLK55 and C204 350 I only use M mode 'Paddle shift' when I'm going for an over take - I select the appropriate gear then go for it.
All MBs have slow M mode apart from the SLS but that's a Ferrari DCT box.
I use it for engine braking all the time.
Apart from that it's too slow to be of any real use.
I'm not giving up on you yet, Ricky! :rock:
I'll make you one of those audio help things for when you're sleeping..
ZzZzZzZz....
"Use the paddles, Ricky... Feel the benefits of the paddles... Manual is the way forward... The paddles are your friends... They want to help you, Ricky..."
ZzZzZzZz
:D
Rashman said:
I'm not giving up on you yet, Ricky! :rock: I'll make you one of those audio help things for when you're sleeping.. ZzZzZzZz.... "Use the paddles, Ricky... Feel the benefits of the paddles... Manual is the way forward... The paddles are your friends... They want to help you, Ricky..." ZzZzZzZz :D
Hahaha this is brilliant!!!
Loved reading all the opinions... Definitely going to spend more time using them and getting used to them. X
Sent from my iPad using MBClub UK
Yes, I'm going to make Ricky my "test subject" :D
I am determined to convert him.
Great to hear you are going to give them a go.
Start by trying them out on empty stretches of roads.
If you haven't used paddles before, they can be a bit disorientating.
For example, you don't need to let off the gas when changing gear.
Sounds like stating the obvious but you'd be surprised how much your brain is a creature of habit.
Your brain will be well used to how to operate a manual gearbox, and equally used to how to operate an auto gearbox.
But mix the two together and you'd be surprised how much acclimatising it takes.
Like patting your head with one hand and rubbing your belly with the other.. take abit of getting used to! :D
Have a play.
See how it behaves and get a feel for it.
:thumb:
Rashman said:
Yes, I'm going to make Ricky my "test subject" :D I am determined to convert him. Great to hear you are going to give them a go. Start by trying them out on empty stretches of roads. If you haven't used paddles before, they can be a bit disorientating. For example, you don't need to let off the gas when changing gear. Sounds like stating the obvious but you'd be surprised how much your brain is a creature of habit. Your brain will be well used to how to operate a manual gearbox, and equally used to how to operate an auto gearbox. But mix the two together and you'd be surprised how much acclimatising it takes. Like patting your head with one hand and rubbing your belly with the other.. take abit of getting used to! :D Have a play. See how it behaves and get a feel for it. :thumb:
Yes it is the case of head ruling the body I suppose, just what you get used to in a standard manual. No I didn't take my foot off when I changed gear with them the first time so must already be a natural haha!! Really learnt a lot from the posts though - didn't know you could still use them in auto? Now that again seems a little strange just for the fact that it should be one or the other but hey ho... Merc like to give options I suppose & they're luxury for that reason. I've not really seen what it can do yet so I'll try that today... Definitely on the open roads. It drives beautiful though. I'm so glad I've got it & got so many variations of 'how' to drive it too. X
Yes, I know what you mean. There are alittle too many options.
Far too much choice.
But choice is better than no choice, I guess :D
In mine, I have auto modes "C" & "S".
Then I have the paddles in "M" mode.
Then I can choose to change gear with the gear shifter when in "M" if I want to.
Then I can choose to change gear in auto mode with the paddles.
Then I can choose to change gear in auto mode with the gear shifter.
And if I really want to, I can even change from 1st to 2nd using the transmission selector button! :crazy:
Being able to change gear while in an automatic mode is mostly for when negotiating steep gradients.
For example, when going down a steep hill, you can change down gears to limit the maximum gear that the gearbox will shift up to. This helps utilise engine braking to take strain of the brakes (or to aid the brakes) and help keep the car and speed under control.
Love your work Rashman. Paddles are the future :thumb:
Hey Blondee, when you get round to cleaning your car be sure to run the results past Rashman..... he is the judge of all things clean on this board :D ;)
:o
The world of OCD is a cursed land :(
:o
I know, but you have made me feel better as I thought I was the only one on here doing crazy things like trying not to touch the paintwork (which is why I was so incensed by the cyclist incident ;) ) and watching over anyone working on my car like a hawk :D
Safety in numbers Rashman, safety in numbers :D
Ah, yes, our friend Gweedo the cyclist :rolleyes::mad:
:D
:D
Yes good old Gweedo, that thread sort of went crazy. I realise now I should have battered him LOL! ;)
Just kidding before the holier than thou brigade turn up :D
