andrewcliffe
ok, whats the best method of cleaning them? Naturally I don't want to contaminate it further!
andrewcliffe said:ok, whats the best method of cleaning them? Naturally I don't want to contaminate it further!
Sorry, but I think this is twaddle.
If you expect a slight improvement you will get one.
The only sure test is a blind one.
My car goes faster as I drive out of the car wash, maybe there is a link?
Standing start, foot to the floor, give it the beans. I've been advised you might need to do it a couple of times. Job doneThis reset procedure...do you press the pedal all the way to kick down or not?
will this work on a c250 mine wont shift gear is there limp mode on these cheersFound this on the US MB slk forum... was a little scepticle at first until loads of guys reported that their cars were quicker off the line, changed gear at more optimum points etc, so I tried it and it does indeed seem to work!
The long way to reset the gearbox memory is to disconnect the battery for 30 minutes - but follow this quick procedure and it can be done in a couple of minutes!! Give it a try yourselves and post the results if it works!!
" 1. Get in your car, it doesn't matter if you close the door or not.
2. Turn the key to the on (not start) position, the position just before the starter turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back to the "off" position (don't remove the key), then release the gas pedal.
5. Wait 2 mins for a full alignment.
6. Drive the car as you always do.
Depending on your driving style, this may or may not be a big factor. I do a lot of city driving so I noticed a big change after erasing my history. It is not hard to do this, just follow the instructions - Key on, pedal down 5 secs, key off, pedal up, wait 2 mins. Keep the key in for the entire thing. Seems to work on mine. "
