S211 tailgate strut replacement notes
selphy
Mercedes E220CDi
[FONT=&quot]I replaced my lazy S211 tailgate struts today. Here are a few notes which might help you if you are considering the job yourself. It took me about an hour to do the first side and 15 minutes to do the next side as by then I knew what I was doing.
I got the new ones from ebay, listed as Febi Bilstein 32045 and 32046 for about £50 each which is less than half the main dealer price. They turned out to be identical to the original and once I opened the packaging I found they were labelled Stabilus just like the originals. You might want to also buy some spare expanding plastic trim rivets as they're easily damaged.
The MB procedure which has been posted on this forum previously is pretty good but these notes might help. Note that this procedure applies to cars without the automatic opening tailgate. To do the job you'll need:[/FONT]
  • [FONT=&quot]A small flat blade screwdriver.[/FONT]
  • [FONT=&quot]A big flat blade screwdriver.[/FONT]
  • [FONT=&quot]A torx screwdriver.[/FONT]
  • [FONT=&quot]A long reach flat tool. I used a long wooden ruler.[/FONT]
  • [FONT=&quot]A really bright torch and preferably a head torch too.[/FONT]
  • [FONT=&quot]Something to prop the tailgate up. I used 32mm PVC waste pipe.[/FONT]
  • [FONT=&quot]Suitable tools to remove / release plastic trim rivets.
    [/FONT]
  1. [FONT=&quot]Open the tailgate and prop it up safely. Replace one gas strut at a time. Be careful that your prop doesn't fall out when you've got your fingers in the mechanism. The tailgate is surprisingly heavy and I think you could easily mangle your fingers if things went wrong.
    [/FONT]
  2. [FONT=&quot]Working in the car, remove the cargo net securing trim in the headlining using a Torx screwdriver. Do this before your hands get dirty.[/FONT]
  3. [FONT=&quot]Using your long flat tool (e.g. long wooden ruler) through the box section accessible near the tailgate hinge release the plastic cover plate from the end of the section by applying downward pressure on the plastic cover plate release tab. You'll need to shine a bright torch into the box section to see what you need to do.[/FONT]
  4. [FONT=&quot]Working in the car again, recover the plastic cover plate through the hole in the head lining. It's a bit fiddly to remove unless you've got long fingers.
    [/FONT]
  5. [FONT=&quot]Remove the 2 plastic expanding rivets that secure the trim which covers the tailgate hinges and loosen the trim. You don't need to take it out completely - just move it out of the way.[/FONT]
  6. [FONT=&quot]Pull away the tailgate rubber seal trim in the region of the hinge and down the side edge of the tailgate.[/FONT]
  7. [FONT=&quot]Remove the 5 plastic side-trim expanding rivets and ease the trim to one side.You don't need to take this trim off completely and if you do try it might break at its narrowest point next to the rear light cluster.[/FONT]
  8. [FONT=&quot]Using a small flat-blade screwdriver, release the ball-joint locking spring tab from the end of the gas spring. There is a flat on the outer edge of the gas strut socket which you can push a small flat screwdriver in. If you then lever the locking spring tab just enough to unlock the ball and socket.[/FONT]
  9. [FONT=&quot]Using a big flat blade screwdriver, lever the balljoint socket of the gas strut off the hinge ball. You can carefully lever it against the hinge itself to do this. It comes off quite easily.[/FONT]
  10. [FONT=&quot]Now wash your hands again or put on some vinyl gloves to avoid oily marks on the headlining[/FONT]
  11. [FONT=&quot]Using a big flat bladed screwdriver poked through the cargo-net securing trim hole in the headlining, pry the gas strut balljoint socket off the ball which is attached to the car body.[/FONT]
  12. [FONT=&quot]Ease the gas strut out from the area around the hinge.[/FONT]
  13. [FONT=&quot]Check the new gas strut is identical and open it's locking spring tab a little.[/FONT]
  14. [FONT=&quot]Slide the new gas strut roughly into position.[/FONT]
  15. [FONT=&quot]Now the tricky part. You have to manoeuvre the end of the new gas strut so that it's socket part rests on the ball part which is attached to the car body. I found this easiest to do through the hole in the headlining. Take a good look with the torch then do it by feel.[/FONT]
  16. [FONT=&quot]Once the balljoint socket is resting on the ball you can use a big flat blade screwdriver to push vertically down and snap it into place. It needs a fair bit of force.[/FONT]
  17. [FONT=&quot]Press the other end of the balljoint socket onto the ball on the hinge in a similar manner. You might need to slightly raise the tailgate to get the alignment right before it will go on. Make sure the locking spring tab on the gas strut socket re-engages properly.[/FONT]
  18. [FONT=&quot]Refit the covers and trims.
    [/FONT]
  19. [FONT=&quot]Do the other side.[/FONT]
  20. [FONT=&quot]Notify your other half about the work so they aren't taken by surprise by the energetic tailgate lift. They might also complain it's harder to close if they've got used to it dropping down easily.
    [/FONT]
This is an excellent guide.
I followed the instructions today and swapped out the struts in about 2 hours taking it slow and easy.
My comments ...
I could release the plastic cover plate from inside the car - if you squeeze it, it pops out.
A small motorcycle tyre lever was just the right shape to get in the hole and lever the balljoint socket off the ball.
Very true!
Sorry I forgot to take pics - but it's quite a straightforward job to do.
Once you remove the cargo net securing trim in the headlining you can see the end of the strut with a torch and its more accessible than it sounds.
Once you remove the trim around the tailgate area at the other end that part is easy to see.
Once I'd done one side the other side only took 15 mins to do.
Thank you for the post. Wish I'd had it a couple of years ago when I needed to do the same. It was irritatingly fiddly from first principles
Those Febi bilsteins are the same as the original branded kit, both on my old E500 and on my 535d touring which has also needed the same done after 10 years in place.
As you've said, EBay is the best place to source them.
Your post will save others a goodly chunk of time.
I don't like the idea of removing the headlining. It's things snapping and not going back together that worries me with interiors. But the cargo net, trim do we need to go that far back, or are you referring to just the pull back cover that slots into the trim right at the back of the boot by the bumper?
You don't need to remove the headlining just the cover marked in the first picture.
Behind the cover you will find the end of the Gas strut on a ball joint which you can lever off the joint.
The cover is held on by a torx screw.
The tailgate end is easy to get to - you need to remove the plastic trim by removing the various plastic fixings - once done you can see the other end of the strut.
Hope that helps !
I've got that bracket/cover off where the cargo net goes, now there's the metal bracket behind which which the Torx fits to, I can't get that off. It feels as if that has to come off as I can't remove the cover/plug which exposes the gas strut with the bracket on.
Found a way in, it was very tricky moving that plug around. I just wanted to have a look first, I haven't ordered any struts yet. Just been looking, they're very expensive ones too.
Does anyone know the actual difference between the struts for auto tailgates and struts which are non auto? From what I can see, the only difference is a spring.
Yes those struts are the ones, with the springs. There are also ones for the tailgate without springs, perhaps the auto tailgates are using the mechanism in place of the springs. However, I wasn't expecting that price tag.
SGS ones are for the boot floor (spare wheel I think. Just wasted days waiting for them to arrive and now have to send them back. I've phoned up and told them to change the website making it clear they're not for the actual tailgate. Ordered Febi ones now so have to wait 3 days for them with all the trim off.
I removed the big trim going down the edge of the tailgate , it made up so much easier to pop the clip off and get the strut out but you do break some very old plastic clips.
In the process of doing this and all fairly easy only I ordered these from SGS and they're totally not right , I think someone said they might be for the floor panel in the boot!! Not the actual tailgate as advertised. Wasted days waiting for them and now I have to pay to return them as they won't accept any responsibility. https://www.sgs-engineering.com/gsc1672-mercedes-e-class-tailgate-strut...don't order these !!!
Ordered some correct FEBI ones. In hindsight if i'd removed them first this wouldn't have happened but I wanted to fit them instantly.
So the clips do break and I found the exact ones from vehicleclips.co.uk
These Push Pin Plastic Rivet for Bumpers & Arches, 5mm Hole, Mercedes A0009903492
and these Interior Trim Panel Rivet, Mercedes-Benz A0009915940
