I'm trying to register, but I cannot even understand what category to follow...
Sign up to file returns online -> I guess no.
Tell HMRC you're a new business, new employer or new to VAT -> It could be this one, but it says that it is only for taxes...
Register for Machine Games Duty -> no.
Qualifying Recognised Overseas Pension Scheme -> again no.
Register for VAT Mini One Stop Shop -> no.
Register for Foreign Account Tax Compliance Act -> I guess again no.
you will need to create a gateway account:https://www.gov.uk/government-gateway click on sign up and register as individual
Ok, should I select the
Used vehicle import pack – Application to register a used imported vehicle for use in the United Kingdom
or the
V55/5 - Application for a first licence for a used motor vehicle and declaration for registration
SELECT USED VEHICLE IMPORT PACK
Do I need to have already an UK address or can I start it from here?
YOU NEED TO HAVE A UK ADDRESS THAT OF COURSE MATCHES OTHER ID REQUIREMENTS
Good, very good, thanks!
I have been talking with my mechanic and he told me that it is possible to adjust the beam deflector to remove the "spike" on the right side and have the light leveled, in case I don't want to change the entire block. According to diagram 1.8 Page 4 it should be accepted, shouldn't it?
WHAT I MEANT WAS SIMPLE DEFLECTORS LIKE THESE :HEADLAMP BEAM DEFLECTOR LHD LEFT HAND DRIVE MOT APPROV | eBay IF YOUR MECHANIC CAN MAKE SOME ADJUSTMENTS IN LINE WITH MOT REQUIREMENTS WELL AND GOOD, BUT MAKE SURE ITS DONE CORRECTLY. I'VE NOT HEARD OF THIS BEING DONE BEFORE
I'm a bit confused about this. I understand that I will get the UK plate at the end of the process, so how can I have a UK Insurance before having the car registered?
MANY INSURANCE COMPANIES IN THE UK WILL INSURE WITH THE VIN/CHASSIS NUMBER IF YOU EXPLAIN WHY
Driver license can be from outside UK or should it be already converted?
THE IMPORT PACK WILL INDICATE VARIOUS FORMS OF ID AND ADDRESS THAT YOU CAN USE BUT I WOULD GIVE THEM A CALL IF YOUR LICENSE IS YET TO BE CONVERTED.
Is it explained somewhere how to pay these fees?
YES AND IT'S THE OLD FASHION WAY I AM AFRAID - CHEQUE ! DONT REMEMBER CC BEING ACCEPTED AS IT'S DONE BY POST ONLY. NO OVER THE COUNTER WALK IN OFFICES ANYMORE.
A huge help! Thanks again!
