D
SPX said:There's someone on the Discovery forum with this unreliable scrap of junk: http://s1122.photobucket.com/user/s...4-4EA5-9AF6-1084915A307D_zpsaa1lb4rf.jpg.html
He must of gone through a few engine changes.
Since he's had it though he's had numerous gearbox problems with this one and his old one. Thats one thing which has always put me off.
The ZF gearboxes are sensitive to the ATF used. ANYTHING other than Lifeguard 6 fluid (the ZF box was developed and tested using this fluid) is asking for trouble. Many independent, and believe it or not, some Land Rover dealerships, use alternative fluids which are of a similar specification, but not the correct product.
Is yours a 6-speed 6HP26X gearbox? The specification is ATF M-1375.4. So long the oil meets this specification, it is safe to use with this gearbox. There's a few oils available. Mine runs Millermatic ATF-DM. I had Millers Oils confirm the compatibility with ZF before I went with it. Put 3k miles on it since, all good.
my wife said she didn't want anyone to think she was a Traveller. I tried to point out that this was not a Mitsubishi or Toyota etc
Yes, as I mentioned earlier the base spec is Shell 1375.4. My box is 6HP26.
However, in development of the box, ZF added various things to aid certain functions, so although you might get away with a fluid that is 1357.4 there's no guarantee the box will behave perfectly and premature failure could result with the main risk being overheating (fluid expands) at extreme operating conditions.
Lifeguard 6 is mystery in that no-one knows what additives are in it. If I had developed the fluid, I wouldn't reveal its contents if I could sell it at a higher price than the available equivalents. That said, it has come down in price over the last year or so.
gvm, if you have an itch for a FFRR, then that needs scratching, accept no substitutes!
as SPX stated earlier, the 4.2 V8 was a terrific drive
Must have lived a long way from the garage he endlessly had it repaired at?
If no-one knows what additives are in the ZF oil, how do we know they are there in the first place? This "mystery" allows LR to charge £19 per litre.
Millermatic is popular with the 6HP26 people and has been for a number of years. I think the key is to flush rather than rely on 'Life'guard-ness of the ZF. That said, if LR dropped the price to a reasonable level, I'd be using that but I just felt rebellious.
At the end of the day, they all adhere to the same standard. No doubt some do better than others. Can recommend Millers as using it myself.
Happy birthday, btw.
