I can neither condemn nor defend it without further statistical data.
It would be unfair to simply compare the number of BEV battery failures to ICE engine and transmission failures, because there are around 40m cars on our roads but only 1.5m of them are BEVs - of course ICE cars will come out very bad from such a direct comparison, but this isn't statically valid. And, equally, ICE cars will suffer badly if we simply go by anecdotal evidence from frustrated members on here who needed a new engine or transmission due to known manufacturing defects.
The real question here is whether BEVs are overall more reliable than ICE cars, and I don't think that there's enough data in the public domain to answer this question right now. Especially since the data needs to be more granular - for example, AdBlue issues can be very expensive to fix, but they only affect Diesel cars, so in reality these are easily avoided by not buying a Diesel car. Equally, BEV battery failures might be more common with some makes when compares to others, again not an issue if you know what marques are best avoided.
Where ICE cars do have a clear advantage over BEVs as far as potential buyers are concerned, is that there's plenty of info out there if you're willing to look it up. The V6 balancing shafts, the M157 head bolts, the M271 sprockets, the CVT transmission (all of them), and farther afield the Nikasil engines, the Rover 1.8L, etc etc - the info is out there, all a buyer needs to do is carry-out some online research. With BEV, it is far more difficult to find reliability data because BEVs are still far less common than ICE cars, and so yes, it can be a bit of a gamble choosing a BEV marque that has a good reliability record. Which is obviously a problem.
Having said that, there might be a compound answer to your question. How can you defend the two Boeing 737 crashes, that killed 346 people, due to a poorly conceived MCAS system? The answer is that you can't, BUT at the same time, the fact remains that commercial air travel is still the safest mode of transport known to mankind (excluding walking). Is this a valid answer to your question?
