Firstly I sourced a diff for the car but it's a 3.91 and I most likely have a 3.64 on it at the moment. The car is flat as expected for a non-turbo and I was wondering how bad it's going to make it (I believe the 3.9 makes the engine run at less RPM for the same speed...)?
Secondly I'm having a bit of an issue getting first gear, sometimes. For the first time today I couldn't get it in that or second, only rolling the car a bit makes it go in so if I forget to do it before stopping it can be an issue. The other gears are slick. It's not all the time and normally just needs a little more push than the other gears. I also noticed in 1st/2nd if holding the gear stick it can jerk a bit through the stick though this may be unrelated and normal.
Just another problem to add to the list of my poor automotive cockroach.
