SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
Hi
I have a minor fuel leak on my clear plastic pipes (ones that go to/from the fuel filter).
I have replaced the 3 O-rings at the fuel filter and 1 at the pre-filter easily with VITON seals. This fixed the fuel leak at this end (which was squirting around the engine bay at one point!! eek!)
I still however have a leak at the other end of these clear pipes. This seems to be causing me a cold start issue. When the car is left standing the fuel that goes from the fuel filter leaks out so there is no fuel in the pipe in the morning, making starting a big problem. Car starts for 3 seconds fine, but then cuts out - i assume it uses the fuel in the filter and then there is no fuel in the pipe so it cuts out. i then have to crank for ages to get it to start.
When running there are small air bubbles in the pipe aswell.
Basically i am hoping that replacing these bottom O-rings will sort the issue. Problem is they seem hard to get to.
I seem to be able to access one of them (i think the only one that actually is leaking) from underneath the car when i remove the metal engine shield.
what i need to know is how to remove it - it seems there is some sort of clip on it... is it just a case of pulling the clip off and then pulling the pipe off? as its hard to access i dont want to break anything...
i want to avoid removing the manifold as i dont have time to do that at the moment but i'm stuck with the cold-start problem. so need to atleast fix this one seal in the hope it will cure the cold start issue and then i can remove the manifold when i have more time.
i also need to check the fuse in my OVP relay, but i know the fuel leak is there so this is my 1st point of call.
does anyone have a diagram or can tell me how the lower pipe is connected? i think its the one that goes from the engine to the fuel filter. on the battery-side of the engine bay.
its the lower plugs of the end of the red pipes in the following diagram i need help on how to disconnect:
thanks in advance!!
thanks in advance!!
