Hi there,
I am in the process of retrofitting a 6 Disc NGT2.5 with SD into my 2008 A Class (W169). I had previously installed a Dynavin DYN-MBA but I really wanted the oem phone and Navigation so I bit the bullet and purchased a unit from navizip.co.uk.
I knew that I also need some additional cabling so I purchased a Radio antenna adapter, Bluetooth antenna and a microphone from multims.co.uk. The problem that I currently have is that the microphone does not fit into the existing audio loom - there is space for a connection to the right hand side but the white plug supplied by multims.co.uk does not fit. It does however fit in the socket to left! This socket is already populated and has four cables connected (See Image)
I would really appreciate it if someone could guide me in the right direction by looking at the attached images - could you please tell me on which side the microphone needs to attach? Also could you please help me identify the existing wires (Brown, Yellow, Grey and Black).
I am assuming that one of two things needs to happen - either I get my hands on the correct plug to fit the empty socket on the right of the audio loom. Or, I need to carefully remove the pins on my purchased plug and combine them into the existing plug on the left?
Any pointers would be gratefully received!
regards
StalkS
regards
StalkS
