What's wrong with your current gearbox?
im good with my hands etc but im not savy with taking gear box bits apart,have done suspension struts on my old passat, bearings,oil changes pads and discs,that sort of stuff so going into a gearbox may cause a few headaches
I had a manual gearbox in my first merc, I found the box was fine, if something is feeling sloppy its more likely to be the over complicated shifter mechanism, I would recommend changing the detents mechanism on the gearbox as well, it was an awful plastic unit which broke on mine releasing 3 hardened steel ball bearings into the gearbox, the replacement was metal and of a much stronger design,
