miro
1/ Take a nylon spatula and near the windscreen side of the overhead cluster there is a lens for general front light lighting / entry / exit.
The notch in the cover is where the spatula goes in. The lens pops out easily.
2/ Two small plastic clips are in fact the release catches for the rear facing latches. When pulled toward the windscreen the back of the lighting controller pops out
3/ Cluster hangs out, supported by various cables.
4/ Attached dimming mirror to 6 pin connector just near one end of the cluster. I attached mine next to the main power lead. (30amp cable).
I presume that if you have ICE, Sunroof, lit door runners etc.... there will be several connections. In mine I just had one connection existing. (2 looms on top of each other) - the 6 pin connector was next to that.
5/ Testing -
Whilst the cluster is hanging out, switch on all the interior lights and the mirror should dim. Saves looking for a torch.
5/ Testing -
