Dieseldutch
I need to replace my front brakes but I now getting confused of what to get.
I currently have all stock brakes, but after looking on car parts 4 less there seems to be loads of options, I like the look of the drilled discs but theres different diameters showing for my car, will both sizes fit ? 288mm or 330mm is it ok to change solid to drilled ?
By going for drilled discs will it make any difference what pads to get ?
Ive changed many pads over the years but Ive read that theres a separate brake wear sensor, normally these come part of the pads , will it need replacing as the brake wear message is coming up on the dash.
