Shude, I have the original PDF but am unsure if I would be allowed to publicly post it here as it is not my property or written by myself. It can be found on the following forums
benzworld.org
crossfireforum
Edit:
Also I haven't seen that PDF so I don't know if it just covers non multifunction steering wheels or if he included the radio transmitter/ receiver part?
It only covers the "tip" boxes...therefore the multi-function steering also.
That's not what I meant sorry, originally the mod was done on an R170 which didn't have the radio controls etc on the steering wheel. So it is done differently than the way I had to do it, the original used the horn wire with a box he made to change the resistance of the current flowing down it, so the horn wire would have 3 signals.....1 for the horn, 1 for change down and 1 for change up.
With the multifunction wheel the "one" wire already carries loads of signals for all the switches, so I have a transmitter behind the airbag that the paddles control which a receiver then picks up and provides the signal to the shifter .
Hi Shaun, where did you source the transmitter/receiver from? Thanks, Mel.
benzworld.org
crossfireforum
Hi, I wrote the instructions ... and I would post them here ... but the file is too big.
If anyone wants a copy, PM me an email address and I'll send it,
Chris
Hi Chris,
Well done regarding the mod, an excellent modification, would dearly like to fit it to my C43/55 but I am unable to PM you as you need 30+ posts before PM facilities are enabled.
...I am unable to PM you as you need 30+ posts before PM facilities are enabled.
I have enabled Chris' PM facilities.I have Chris email address so PM me yours and I'll send it to him.
thanks you Shude
Chris
Gistek said:I would defiantly be interested in this MOD considering i have just retrofitted an E55 Wheel to my W211.
Does anyone know if these kits can still be purchased?
Lets see if this can be resurrected!
