W210 fitting new cable to rear window regulator
airstream
I need help in fitting new cables to the rear passenger side RHD window regulator on my 1999 w210 E240
The cables rusted and both snapped so I have no idea which cable fits where or how they sit on the drive drum etc
Is there a pictorial or other simple set of instructions that show where the long/short cables fit, the route of the cables and where on the drive drum they sit
All help appreciated
Regards Ray
Your W210 should be quite similar to a W202 here… New Page 1
The W210 motor has a much bigger electrical connector, other than that its much the same, not sure if it is bolted to the lifting mechanism by 2 or 3 bolts?
I think both cables are the same length, one just appears shorter than the other, depending on whether the window is up or down.
Dec
