W210 Rear Caliper Repair, Kits? suppliers?
stuboy
Devon
E320 Avantgarde Estate W210 Petrol
Hi Chaps
Thought my brakes were a bit on the not so hot side so just taken them apart to find both inside rear slave cyliders are seized.
Do you know where I can get:-
1) rear caliper repair kit
2) a set of shoe retaining pins (I had to drill and punch mine out)
Or should I go straight to Mercedes?
My procedure to get the siezed piston out was as follows:-
Clamp brake line disconnected caliper, 18mm spanner, remove ratining pins and pull pads out.
I cleaned around the seizure as best i could (rubber seal was shot away!)
After cleaning I sprayed with WD40.
I then put a piece of 10mm steal plate through the caliper and put one end in the vice and the other g clamped to the caliper. Tighten g clamp till it grips tight, then I did the vice up to push the slave cylinder back into the caliper. A spark came out of the hose hole as it let go and moved back into the caliper body. That was the hard bit!
Now re-attach brake hose (I layed it on a couple of breeze blocks) and pump the brake until the slave cylinder pops out.
Now all you need is a repair kit if the actual caliper is not damaged!
Regards
Stuart
Sounds like fun! I'd get the parts direct from MB, they seem to be very competative on brake stuff at the mo :)
