After some feed back for hot start problem,
2002 S320 CDI (W220)
Recent work in past 1000 miles
A service with additional work (Prestige Car Service
High pressure fuel pump
Fuel return lines (All replaced)
2x injectors re-seated (new seals)
Symptoms, “Intermittent”
NOTE, currently only a hot start issue not cold start;
Shut down engine after a run (full operating temperature)
Leave standing for approximately 10 minutes
Cranks but doesn’t fire
No malfunction alarms displayed on dash (although I think the excessive cranking would have been logged)
After searching for possibilities (Google is your friend
Crank Shaft Position Sensor
Low fuel pressure due to air ingress (Injector not closing or leaking line)
I’ve found plenty of documented reports with above fix recommendation but not accompanied with post result fix?
Next is diagnostics analyser to recall faults
I’m open to suggestion of things I may have overlooked?
Eddie
![Thumb :thumb: :thumb:](/styles/mbclub/smilies/thumb.gif)
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Eddie
