Smithy860
pardon my ignorance (and eyesight) but what is that?
Auxiliary battery capacitor pack for stop start functions.pardon my ignorance (and eyesight) but what is that?
What sort of crap material do MB use on springs that rust like that? 64 year old 190B still has original springs covered with surface rust.Replaced both broken rear springs on the A Class for the MOT tomorrow. Both broke in the usual places. No noise or issues....but it is sitting more level now. I just thought the old springs were getting tired. Only took about 20 minutes a side.... apart from the wheel bolts you dont need to undo a single fixing to replace them!
I think the problem coincides with the banning of cadmium and similar metals in the alloy used to make the springs. Not just a MB problem.What sort of crap material do MB use on springs that rust like that? 64 year old 190B still has original springs covered with surface rust.
I know, I was following your threadsLooks good Slarti, but I'm biased as I have done the same![]()
It appears to be general trend, had broken springs on Ford Fusion and othersI think the problem coincides with the banning of cadmium and similar metals in the alloy used to make the springs. Not just a MB problem.
Great cars. How long have you had your Ponton?What sort of crap material do MB use on springs that rust like that? 64 year old 190B still has original springs covered with surface rust.
7-8 years. I had an almost new one in East Africa for 7 years. No broken springs, plenty of shocks, on rough corrugated dirt roads, Strong cars.Great cars. How long have you had your Ponton?
Occasionally the coolant level light pops up on one of our cars and then disappears for months. The level looked OK to my untrained eye, and as it doesn’t ever come back on I assumed that it was an error.
It’s happened a couple of times - but not every time - in the last month, most recently yesterday. It popped up immediately when I started the car today so I called in to the main dealer to check and top up.
The level looked OK, so they have run STAR diagnostics in case it was a sensor issue but no fault codes were present/ they have topped it up with just a dash in case it’s especially sensitive to level.
Anyone had something similar with coolant level?
