Hi Bobby,
W210 pre-facelift and W202 pre-face lift and facelift door mirrors are the same door mirror.
The W202 mirror has even got a 210 pt. no. as the links below show
Hi Bobby,
Thanks Shude - perhaps I should elaborate: My car (1999 C43) swapping mirrors with pre-facelift W210 BUT which has had W210 facelift mirrors fitted... still ok?
"These" facelift w210 mirrors are direct fit as they have been already converted from facelift 210 connectors to pre-facelift 210/202 connectors. and will require no modification at all.
You will however have to run a blinker supply up from the cable trunk under the door sill from each side.
The mirrors that bobby could be getting are facelift 210, that already have had the correct connectors fitted for a pre-face lift w210 or w202, so they will plug straight into his car and everything will work apart from the blinker
if the 210 was a pre-facelift with facelift mirrors, you will need to mod the wiring depending on how the 210 mirrors were modded. if the plugs were changed on the mirror side, then only a few pins and additional wiring would be needed.
2017 CLA 180 AMG in Black (mine) 2018 GLA 200 SE in Black (wifes)
The mirrors were originally modded for a w202.
They will go straight on, but has been said, you will need to run a supply for the live of the flashers.
Do your w202 ones look the same as the pre facelift w210 ones?
Hi Graeme, Yes I checked they are the same! PM me and let's come to an arrangement if possible? More than happy to come down your neck of the woods if needed.
cheers
