SavMan
The instrument cluster display would be interesting, you could also look at a away to use the aux input of the Comand unit (if you have a TV unit installed) to display your data from your data logging app.
I can check what the map does for the fixed SC pulley to see if it uses the smaller TB to release boost as a safety measure as that's the only way I could think you could instantly reduce boost but it would be good to get some data on a car without a pulley first.
The 103C is a bit of a red herring as you obviously had a problem either with your pump, heat exchanger or air in the system on your stock system.
10C I presume is the temp the water in the tank has been reduced to when not under load, that's like driving round with the box just filled with ice ALL the time ready for a blast
The interesting part will be how quick the temps rise, peak temps and recovery. Can you also log the Boost at the same time it should then be possible to calculate the effects of increasing the boost through a pulley change.
You probably won't notice it now that summer is over but interested to see how your AC in the cabin copes, I don't think you will have an issue as our summers don't work the AC that hard. Only ones that seem to have an issue are those that live in hotter climates, some of then are looking at adding a higher capacity AC compressor to compensate.
