- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
guyvert1 said:Nice quick cool downDo you have the front mounted one ?
Yes, built by us.
with just a EC uprated Heat Exchanger
Problem is this time of the year testing is pretty pointless, most 55s wont suffer with heat problems if running well
loads of data logging
Maybe you could share that data so other forum members would benefit from your experiences.
I have already stated what I think works well, data logging on my old car is irrelevant to others for various reasons, the path I took is already proven to work well, most would agree a simple HE upgrade is enough, that why most choose that option, even with ChrisAs new improved power (Stage 3) , he still does not suffer cooling problems, I thinks that's testament enough.and why most members run only the HE
So to clarify: remap with standard cooling works well with just a bosch 10 pump, pulley either SC or Crank then I would recommend upgraded HE and colder plugs, if your planning to track or do high speed runs then possibly ice tank, this information has been around for a long time, but as I have always said I will put maintenance on these cars well ahead of any mods, and pulling 567bhp on a dyno with just a remap from Jerry was one of the most powerful CLS55s ever seen, and was all standard at the time, but well maintained.
Cheers Billy, got to leave it for now leaving for work shortly, will be spending most of the night monitoring pressures and temperatures, you would be surprised as to the difference half a degree can make to power outputs.
If the lights go out its not me![]()
As Billy said, I have no heat issues whatsoever and I do work the car very hard. The EC HE combined with IC30 and colder plugs seems to work fine
I am having split-cooling fitted by Acid's team hopefully on Wednesday but this is purely as I will be hitting the 200mph + speeds for a good few miles, as I have been with my Summer tyres before, albeit with no issues. This is purely a "Better safe than sorry mod" for me
Chris - can you post some pics up of the installation when complete. I assume you are going for the weistec boot mounted tank. Looks a nice bit of kit.
Maybe we should not state "Heat issues" as most people view this when they can feel the ultimate power stopper i.e. the SC disengage.
The fact is and always will be keep the air charge as cold as possible increasing the efficiency of the SC, as the air compresses heat is generated cool this down you can get more air into the engine/more fuel/more power.
I bet when you split the system you will feel a big difference in the power, and the difference i mean is that its the fast reduction in air temperature allowing the car to go WOT repeatedly, the only way to describe mine was it felt like the power is always there and the car is always eager.
BHP on the dyno is one thing but maintaining those levels is difficult as the heat soak and recovery times increase on the stock system.
I really need to understand the cooling system on our cars more. I am still thinking I like the idea of adding another HE to run in series with the current one (in my case a EC HE). I'm trying to find out a little more about the S55 cooling system as I think for whatever reason the S55 had exactly that. I think it was the only 55K variant with an additional HE. I know we haven't got much room but something can be done I'm sure.
Simon how about this, seems a bit off the wall but???? post #24
10 second club members..... post your mods and vids - MBWorld.org Forums
Had mine on the rollers for the first time yesterday so am no longer a dyno virgin, just a power run not a dyno tune producing 534bhp, it was a bit strange watched 6 c63's first on and off the rollers but when mine went in it was bucking like a bronco and moving around, it seemed that the operator was surprised with the torque am sure he wasn't, is that a common difference to see between the two types of car?
The operator did comment there was much more power available and mentioned over fueling?
Dyno experts please comment.
