CaptainChaos
I use E-SAVE for going up very big hills and very cold mornings, otherwise leave it in Hybrid and be as smooth as possible.
Yup, its this bit thats a bit annoying. It seems to me that when i get down to the last part, it gets to about 11% and then engine on, once is regens a little bit of charge it cuts the engine off - uses it and starts it back on again which seems a bit pointless when its literally for about a second or so. Loving the E mode only though, wish the range was more then it is! max charge i just show 15 miles but i guess it is cold and the car is second hand.Eventually, once the battery is down to 10-20% (depending on mode etc), it'll keep running the ICE no matter what you try to do. I too find it a bit disconcerting the way it cuts in & out for barely seconds at a time - can't help feeling it wold be better if it had a minimum ICE run time of 20-30 seconds. At least it could be charging the battery if it wasn't using the power to move along the road, but no doubt MB did their sums and decided it needed to do that to achieve the target emissions limit. So, they sell a few more starter motors....
I got C350e 66 plate 48k bought last year Feb20 as 2nd owner it’s been fantastic with no problems and for me personally I achieve best possible performance/ MPG on Eco/EV for local/running around and motorway for added power C/Hybrid or S/Hybrid on windy conditions.Just did my first long drive with the battery on 100%.
So strange from driving a 'dirty diesel'
Partly the hybrid but also because it's new... I was driving like a granny!
Just wanted to ask, what is the actual best way to drive this for economy.
I get that charge mode is terrible.
I tried e mode and really enjoyed but, switching to hybrid, I found the engine constantly coming on and off.
Was confused that e save still uses the battery sometimes as I tried that for the motorway portion.
I've read the manual and descriptions but what's the real world opinion where I'd be driving mainly 30 and the occasional A road.
That is a good question. It is interesting to see the different responses and that we all drive the car differently.Just did my first long drive with the battery on 100%.
That sounds like it was a very satisfying job Captain.Exciting DIY post!
I've noticed over the last couple of weeks a bad judder from the front brakes when braking from reasonably high speed. It seemed to come after all the snow we had. I read a thread which said that the brake pad pins can seize and it can sometimes come across as if you have a warped disk so I thought it was worth a quick look. Sure enough the top pins on both sides were very tight and took a lot of "persuading" to leave the caliper. The bottom ones weren't quite as bad, but they all benefitted from a clean up and some copper grease. It seems to have solved the problem. I am sure the main dealer would have been very quick to put some new disks and pads on!
This isn't a problem unique to MB. It's a legacy of the modern way of "servicing" which involves sticking your car on a ramp and looking at it for £XXX, but not actually doing any preventative maintenance.
Some pics:
View attachment 109520View attachment 109521View attachment 109522
What would be the benefit of driving in E-SAVE instead of HYBRID,just curious?That is a good question. It is interesting to see the different responses and that we all drive the car differently.
To answer your question, the most economical way must be eco and hybrid, especially when the ev battery is low.
I drive in e mode for short journeys. For longer journeys I switch to e save mode (even when battery is fully charged) and stick it into e mode about six miles from home. My wife drives it in hybrid mode.
I am not really bothered about driving the car economically and reflecting on it, if I wanted an economical car I could have bought a Prius or held onto my VAG 1.6TDI. Once it isn't costing a fortune to run it doesn't matter as we don't do big mileage anyway. If we did we would have went with the diesel.
Agree with Chris that Hybrid mode would be less annoying if the ICE was programmed to stay on for at least 30 seconds. I was out walking the dog yesterday and a 350e turned the corner. I could really hear the starter as the engine kicked in as the driver accelerated after taking the turn.
@dasachmo Don't know if they are sealed, but if you look in the manual, it points out that depending upon atmospheric conditions ect, the LED headlights can have some condensation (which disappears, i.e. it's not permanent)Does anyone have any advice about the headlights.... So I washed the car today with warm water, noticed one headlight had a bit of condensation on the inside afterwards... They're sealed units right?
It’s a feature, Sir... but seriously, it’s normal for a bit of condensation to form under those conditions. The headlamps aren’t sealed units.Does anyone have any advice about the headlights.... So I washed the car today with warm water, noticed one headlight had a bit of condensation on the inside afterwards... They're sealed units right?
@seekay Yes 600nm is correct. The figure of 443 you cite is lb/ftAre we sure about the 600 Nm combined torque? Is it not a wrong math?
This only mentions 443 Nm HERE
The rivals 330e/530e also around ~430-450 Nm, I always wondered why the C350e has much more torque...Maybe someone just added up the electric motors and engines torque which is wrong...?
@seekay Just because something is higher on a spec sheet doesn't necessarily translate to "better" performance in the real world. There are so many factors beyond power and torque numbers in terms of how a car actually performs. I chose the C350e over the 330e after test driving them both because of luxury and comfort, but I wish the C350e had the 8 speed gearbox from the 330e, it's a way better gearbox than the MB box.Thanks, I can have a good night sleep now.
Was just wondering when checked out the rivals BMW specs and their torque is much lower for some reason. Maybe the explanation is just simply MB is better.![]()
I had a 2016 F10 5 series before the C350e, wasn’t impressed of the 8 speed ZF either. Was less jerky than the C350e but other than that it was a very similar experience.@seekay Just because something is higher on a spec sheet doesn't necessarily translate to "better" performance in the real world. There are so many factors beyond power and torque numbers in terms of how a car actually performs. I chose the C350e over the 330e after test driving them both because of luxury and comfort, but I wish the C350e had the 8 speed gearbox from the 330e, it's a way better gearbox than the MB box.
@seekay If you go online and get a quote, it gives you one price but also shows you if additional work is required (like spark plugs etc) and the price of those additional items, and you have a choice of deselecting the additional items and just booking the service only (but that may impact your warranty cover and your mobilio cover)Anyone who has experience with the annual A and B services at main dealers.
At a certain year and mileage additional maintenance required beyond the usual engine oil/filter, pollen and air filter changes, such as gearbox oil, differential oil, spark plugs, belts, etc. When the time comes for these the standard A and B service price will include them or will be an additional charge?
