Do you have any photos of the ones done by Projex
IIRC there is a thread on here names Project 507, or 507 bonnet/Projex where you can see the finished article and pick it apart!
Is anyone running number plates fixed to the front with just sticky pads? Mine has a number plate surround which I’d like to do away with but don’t want to have screws and plastic caps through the number plate. The front has quite a bend in it so not sure if sticky pads will hold it with it wanting to straighten up and spring off
Careful as when you remove the front plate holder you’ll realise it too was held in by screws, so you’d need to fill the bumper... which by the way looks beautiful without a holder. I am thinking of removing and filling/spraying and buying a stick on plate for the side like Boon/Syrius9 has done
Gents,
I’d like to fit a carbon fibre defuser, centre part to the front spoiler, rear boot spoiler, and mirror housings.
I don’t want to change the design, I want them all stock design, just in carbon fibre.
I’m a little overwhelmed by the choices on offer from different suppliers and fear buying parts that don’t fit or look right.
Can anyone point me in the best direction?
My car is going to Unit17 in Birmingham next month if all is well, they have carbon everything for the W204, OEM fitment and a very good reputation. They supply and fit, or you can order and fit DIY. I am going for mirrors, OEM rear lip spoiler and possibly the black series lip although they don’t stock that
Rear diffuser I am going for the Vorsteiner. Obviously ‘real’ carbon will set you back thousands, I believe Unit17’s items are carbon on FRP but they look fantastic. On their Facebook and Instagram you can see another 507 in red which has had products from them, including a wealth of regular 204’s
The rear lip comes off relatively easy, on the FB page there should be a pic of a white coupe during the removal stage of the spoiler. Mirrors come off in five seconds, simply set the mirror glass forward so you don’t catch your fingers when removing, then pull the bottom of the casing towards you, then lift the casing up and off. Transfer the indicators over to the new housing and plug the indicators back in and slide the casing back down on the mirrors
^also be a good time to check your puddle lights (if specced) are in and/or working
