I asked them to do that, they still refused!![]()
That's a shame, and they wouldn't tell you what was involved in that service?
I've asked if they could email me breakdown of what was carried out in each service, 5 services were carried out by them, they agreed to email me which is something I guess
The service book will have ticks of what has been done at each service, so don't worry too much, as long as you know that these are genuine and tangible, which you know they are from the current information.
Looks like decent history, if the gearbox oil change has been done, it will be further down the line past the 37k mark.
So it looks like there is no tangible service history for the period of ownership of the seller? Would advise to have the car serviced right after purchase if you go ahead.
I would suggest checking the colour of the oil by wiping the dipstick on a clean piece of kitchen roll, but 7k in it would be pretty dark anyway.
I guess it would be, but worth checking any way, i've asked the seller I wish to check the car with the engine cold, is this the right thing to state
Yeah, you should be able to feel most engine defects with a cold engine - although I'm unsure on what to look for in these engines, I guess you will need to listen to knocks and unusual sounds, especially the dreaded timing chain rattle.
Not sure on what to look for on the supercharger either.
Basically see the car (behavior) from cold, and make sure that you get it up to normal temperature when test driving, so that you also get a feel for it once fully warmed.
The list is getting longer and longer haha...
Should have a dipstick. near rear of engine next to ATF dipstick tube.
I change my oil every 5k approx and it never looks dirty. Even at 10k I wouldnt expect a smear to be more than bark brown.
The engine WILL rattle for a second or two on startup. That is to be expected. Then no untoward noises except for maybe some belt noise. (not rattle or knock!)
The supercharger on these is pretty quiet - you may not be able to hear it at all.
If I do purchase the vehicle, I'll get it serviced inc the transmission oil, what oils /filters are recommended
Gearbox oil change budget around £180. Olly on this forum (prestige Car Services) does them, but it may be a trek as he is near Portsmouth.
You could make a day of it though and go the Gunwharf quays.
As the OP is in Coventry it would make sense to use Jay at Mercland.
When I first bought my CLK I took mine there for some work and a checkover where he found two broken front coil springs and a faulty shock absorber.
The coil springs were slightly broken on the ends, so not easy to spot.
Jay has free loan cars as well, so is very convenient.
