Hello again,
Stumbled upon an interesting observation, or was this a co incidence...?
The headlight level adjuster (the rotary switch near the headlight switch) had no effect in the level of the lamps, so decided to look into it. Found that the previous owner had (reason unkown) disconnected and plugged the vacuum lines into both the headlights. I reconnected both lines to the headlights and they still did not adjust. Being short of time, decided to look into this later.
About 15 minutes into my next drive out, there was a complete loss of power, no acceleration, similar to a dead turbo. Decided to check on the recent vacuum lines I had fiddled with and on checking, I found that the vacuum line connecting to the right head light had come off. (I probably had not set it deep enough) Reconnected it and the power comes back again!!! Wierd???
So my queries are :
1. Is there any connection between headlamp level adjuster vacuum line leak and loss of power ?
2. I have been given to understand there are 4 vacuum systems as follows:
(a) Headlamp level adjuster
(b) Central locking
(c) Automatic transmission shift
(d) Turbo actuator/wastegate
Is the above correct and if so, are these inter related ie. can a leak in one system result in malfunctioning of the other?
3. There is a hissing sound coming from the area of the headlamp level adjuster rotary switch after reconnecting the vacuum lines to the headlamps. It was not there when the lines were disconnected and plugged. I know this hiss is not 'normal', its obviously a leak. Could this be the reason for the non functioning of the headlamp adjustment?
I am attempting to solve this tomorrow, so would be greatful for any inputs and help.
Thanks in advance.
So my queries are :
(b) Central locking
Thanks in advance.
