heavy power steering abs esp airmatic lights
chrisdovey
brighton
1996 w140 s class 280 and 1987 vw jetta 2.0 16v
so my battery went dead. eventually got it started. now the power steering is heavy and a few seconds after staring the abs light comes on and then it reads esp display defective and then airmatic visit workshop and its stuck in second gear
help please
had a look through the forum and all the other thread i can find all have the bas light aswell but i dont.
this is on my 99 w220 s430
Possible water ingress in passenger footwell (rotted electrics) you don't want this
Wheel speed sensor
Ideally needs the fault codes read and further diagnosis
its been perfect every day untill today. jump started it and now it got all the warnings up
Sorry to hear this. Mercedes are notorious for not liking a jump start. So many electrical systems ready to go wrong.
As above , the car really needs the fault codes read to see what is happening.
right spent all afternoon going through the car with a snap on verdict
first a formost i can access all the control module apart from the abs it wont comunicate with that at all, just asks me if the ignition is on and the scanner plugged in. is this my main problem?
the codes i currently have are
suspension: c1026
gear selector: p1879
engine: p1605, p0720, p0500, p0600
gearbox: 038 and 134
Faulty abs control unit
No live feed
No earth
No can signal
Blown fuse
It could be a number of things, did you check for water Ingress in the passenger footwell?
yes checked the carpets. dry as a bone.
fuse is fine and have a an earth and a live at the abs unit
anyone offer any help
Probably different but I had an issue on my C63 after disconnecting and reconnecting a MAF sensor, heavy steering and esp unavailable.
Just had to disconnect battery and leave it for 5 mins then reconnect and all faults cleared.......
Might not help you but worth a try
