- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Connect the Star and bring up the gearbox temp.
Fill up the gearbox with another 3L of fluid. Put the Car in "D" with the parking brake on and allow to warm up. It can take a while! 80C is the temp to check the oil at.
Dip the sump with the dipstick with the gearbox in "N" or "P".
The highest level is the 80c one. It must be up there for the level to be correct.
You may need to top it up. You will need between 6-7L in total. Just add a small amount at a time.
Re-set the gearbox adaptations with the Star too. This will help you get smooth gear changes.
