Well thats easy, undo filler plug, undo drain plug, drain oil, put drain plug back, fill with correct diff oil to the top of the filler hole and put the filler plug back! Easy huh?
You are right-its a pretty simple job. However like all things the devil is in the detail.
1.You made no mention of the grade of diff/hypoid oil to use or how much.
2. Some limited slip differentials use different fluids and can have a lot of extra " plumbing" and a reservoir in the engine compartment. Wrong fluid could ruin the diff!
3.Getting the oil into the differential can be a bit of a problem if you can't get access from above and you have to "pump" it in via a large syringe. [ folks have used silicon/mastic guns and an empty cartridge in the past] or sometimes the oil comes in a "squeezy" type container with a clear flexible filler tube [ but I see less of these around now]
so a brief write up with pics would be good- will try to find one on line to link to.
p.s. I forgot to mention that you may require an socket set adapter to fit the threaded drain/fill plugs and maybe large breaker bar to free it off the first time you do this.
Every 40,000. I do it for £165
:bannana:
quick thanks to C55 for the "how to".
I managed to do the change today under some humble ramps, however I was very surprised to see the condition of the ATF fluid, very black, no smell of burnt toast, no metal particles, a few bits of dirt fell in from the gasket when I took the sump off, no drama otherwise
Oddly enough I did really try to flush the gearbox out, but the most I could manage was 6.0l exactly, as C55 says, the actual hardest bit is waiting for the bloody engine to warm up to 80 - 90 deg c !
that must have been a good 20 min wait. The sump cleaned up a treat & now I've got 1.0l of spare fluid, may resell back to the dealer ( next time I decide to go there for parts ).
It's a shame the fluid don't say bright red long, even after a quick trip round the block, it's tinged brown already, must be the slug of oil left in the cooler.
nevertheless, the tranny is silky smooth now, much more responsive.
Doubt the main dealer would ever have done it as thoroughly ( in fact they only recommended 3.0 litres ! so they don't bother with the torque converter ! )
cheers
Taz
Great write up, thanks
I am just doing my 1998, 300TD 722.6 auto box, have drained both the sump and torque converter using the small plug -
Is it necessary to undo the banjo and fit an additional pipe for a flush? or could I just locate the oil cooler and drain manually?
Cheers,
You can do this.
Another way is to fill the gearbox with the 3.5-4L then run it for 30 mins then drain and fill again.
Remove the old filter and install the new one. Give it a thump to loacte it. They tend to hang down a bit. This is normal. Note the loacting clip.
Did mine today and it did hang down a bit which I thought was odd, the 'clip' you mention - is this the tang at the back which fits into a slot?
thanks
