You press a button in the event of an emergency and you're talking to a person in a call centre almost immediately. USA-only IIRC.Whats teleaid?
Did you check if the cluster was set up with one or two senders? C43 has two fuel senders
As some of you are aware i am doing the MF steering mod i asked a guy if he can code the new cluster he said yes, but will need the exsisting cluster so he can download info from it. Is this correct or can it be done with out the old cluster?
