He has carbon fibre bonnet , boot lid , door cards and a set of proper coilovers ,a complete evo1 kit bbs split rims the whole shebang !
Also trying to lay my hands on a set of exhaust manifolds as the block didn't come with any, I've seen some Kleeman ones on Ebay, but they're a bit pricey to say the least! and as long as i can fit the wideband O2's into the standard ones, i don't think i need anything special at this moment!
Moving back to the gearbox side of things as this is my main headache!!!
Auto is the way to go, definitely.
The ECU's I'm looking at does have CAN bus interface but to work with the gearbox I would need to know all the programming codes to get the system up and running and information is hard to come by on MB electronics and software.
So, looking at older gearbox options, a nice plain old mechanical system would be good, or limited electronics, such as a gearbox and TCU that don't need to talk to anything else to work. just power from the flywheel, through the torque converter, and outputted on to the drive shaft.
So boys, Gearbox advice down the route of whats already been suggested, anyone got a good idea of what might work? I reckon i can fabricate a bit of a bell housing adaptor if needed!
The 722.6 box does need canbus to work with the engine ECU, afaik However if you can get the engine to work with a standalone then this guy from Denmark has a standalone to operate the g/box including tip levers. He requires the lever, a TPS and a section of the gearbox plug/cable to make it work.
