Update from the DVLA ref the Leaking fuel tanks on 211's
Mr Smith
The manufacturer has responded.
In your email you refer to an action in the USA. NHTSA determined fuel could seep through micro cracks particularly the high pressure pump/internal fuel filter module on higher performance models. It is probable small pockets of fuel build up, releasing a noticeable odour. NHTSA considered the leaks did not present an unreasonable risk to vehicle safety but the manufacturer instigated a worldwide service action to check components and conduct remedial actions as determined at the time of inspection. The manufacturer confirms this action was completed on your vehicle in 2008. This may have included removal of components but DVSA is unable to confirm what, if any were disturbed or what other components, such as piping or seals were replaced.
We are aware of warranty extensions in the USA and have progressed this with the manufacturer. The manufacturer advises this extension is only available in the USA due to significant technical differences between USA and ECE spec fuel/systems. The manufacturer also confirms they do not have record of complaints relating to similar leaks as described, in the UK. A search of our database has not revealed other instances either. As such we are unable to determine a specific defect.
I note your comment on a revised breather but we do not have specific evidence of this component failing.
Having reviewed the available evidence DVSA considers it is insufficient to support further action under the Code at this time and DVSA will not be taking further action on this occasion
However, I appreciate these components are ageing and have noted this for Market Surveillance and advised the manufacturer they must inform DVSA of any further instances.
If you believe the original actions under the campaign were not correctly completed you should contact the manufacturer direct for further advice.
Thank you for contacting DVSA.
Regards
