Nice car Gav! Hope all the box needs a good flush!
Yes bud although not quite as bad, I think the Solenoid gets stuck when the fluid is cold, then with abit of heat it free's up and engages the TC at correct rate. The Post from the Usa forum says it all really. Car is booked into MB Chelmsford Next Thursday for a diagnosis i've expressed my view of what i think it could be so it will be interesting to see what they come up with.
It's a Mb Specialist in Braintree, Under the banner of Waterhouse i believe, And of course i don't know how the conversation went with the previous owner, they may have just requested a Oil fluid and filter change not a complete flush if there is a such a thing or difference even. I've always done mine by draining then driving a hundred or so and doing it again then again with new filter, on the third time the fluid is all nice and red.
Just hope the inside of the Gearbox is in better condition
Jeez you know how to cheer someone up lol,
The Box is lovely when warm, its only the 1st 2 miles it's snatcy, So i think its a Fluid pressure problem, either weak pump in which case id have thought it would do it all the while or a Valve body with duff solenoids which free up when warm and supply the correct pressure of fluid to the TC
Oil pump for the front i've seen for around £375
Valve Body with Solenoids and conductor plate i've seen for £475
You have then have the Trouble of fitting either or both of the above, I may do this myself or if my Friend at MB can sort something Ask them to do it.
It also may just be me being picky, But i wouldn't had thought a car of this ilk would behave this way from new. And i've had at least 15 mercs in the past,
We will hopefully see next week.
Also got the log book back in my name so fitted my new Plate holders and Plates back on
