Rear lower control arm advice needed please. W211
ScottL
2006 E Class CDi 220
In the middle of replacing the n/s/r lower control arm on my 2006 e class cdi 220. Can someone tell me if the inner M12 bolt (12mm tripple square) is threaded through the mount? It wont budge. Thank you in advance
It will be seized, you will have to replace the bush and the bolt.
Why are you changing the rear lower arm?
