rossyl
I'm going to do some rust repair on my car. I had a previous thread on here that didn't get much response, which is odd considering MB's rust!
The Process
From my reading the majority suggest a process such as:
For point 2:
Jenolite I've heard good and bad things. Some suggest just buying phosphoric acid as that's all that jenolite is, haven't been able to find a supplier but that might be the best bet.
Point 3 - I haven't seen any suggestions for the primer to use. Anyone recommend?
One thing I have found is that hamemrite is not recommended.
Cheers,
Ross
I haven't found a decent reasonably priced zince primer.
The Process
- scratch out/grind out rust using a dremel or similar
- treat with some form of rust converter/remover
- treat with a zinc primer
- paint
For point 2:
Cheers,
Ross
