Used this QD for the first time today. I found it easy to use and smelled great. Finish was very good not as good as Poor boys QD but it's alot cheaper and easier to work with.
Clayed it first then used paint cleaner to prep the surface. Then used sapphire power polish, sealed it with nano paint coating followed by premium class carnauba wax finished with BSD. Wheels treated with NPT and tyres and exterior plastic trim dressed with x treme tyre gloss.
Inside done with interior detailer and glass cleaner.
Took about 4 hours but pleased with the result
Will do the CLK with this method when I pick it up from PCS this week and post those results.
Well practised set all the tackle and products out at the beginning so you are not searching for stuff and using a rotary instead of a DA cuts the time down massively. Took a full day yesterday to detail the Golf and Valet the Beetle and Kuga
I see Euro Car Parts are having a mid-month sale. They are already a cheap source at £6.99 but if you spend over £10 and use the promotional code DISCOUNT20 you can currently get 20% knocked off the value of your Cart. What's not to like, two bottles of Sonax BSD for £11.18 delivered. Fill ya boots :bannana:
Having used both products they differ in that Demon Shine is appplied after the car has been washed to give a "just wax look finish".
Sonax is a detailer and as such can be used to clean slightly soiled surfaces, enhancing the paintwork finish giving the paintwork a velvety smooth surface and a brilliant deep shine.
Thanks TooBad, Today ECP have a discount code HOLIDAY20, No minimum purchase. Getting a bottle delivered for £5.49. Local stores OOS. mbclub members causing panic buying?
I'm not sure about it now, seemingly increasingly enhances my orange peel after each application. Where the peel was barely noticeable to very noticeable.
