StevenN
I used the same method to remove my discs today.
I had tried the big hammer approach but they wouldn't budge.
I found that the car didn't like it though ESP flashing like a disco and the gearbox crunched a little getting back into P.
I had to do the same as the OP & put the bolts back in for the passenger side.
It didn't completely free the disc but it didn't take too much persuasion to get it off.
Did a propper job and cleaned & greased the hub so if they have to come of again it will be "simples"
I did find I have a weeping joint where the pipe meets the hose.
Not sure how it goes together to rectify?
I have tightened it up a little and will get my garage to check when they do the MOT.
They did replace the pipes after all.
I had thought to use bolts through the calliper bolt holes to force the disc off but this couldn't be done as the shield around the disc makes the hole blind.
Another vote of thanks to 230K
Steve
Steve
