- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
Yes as per post #31 which you quoted earlier, the engine mount settings will change with suspension setting changes, e-differential settings, engine mode settings, transmission mode settings, etc, and so it’s not really possible to isolate the effect of only the engine and transmission mount differences.Which would explain why people think they make a difference.....its the changes in shock/damper rating they are feeling rather than the engine mounts......?
Being active does not make the engine and transmission mounts more sporting per se, the purpose is simply to provide multiple operating modes. This often to enables the manufacturer to offer a more compliant setting than standard and a stiffer setting than standard - effective timely extending the operating range - all using a single part.
However it could equally be used to offer multiple softer or multiple stiffer modes. It’s up to the design engineering and marketing departments to decide whether it’s required to fulfill the design brief and/or customer requirements, and if so which modes (or settings) are required to do that. That could differ based upon model.
I haven’t seen any published parameters from Mercedes, however the options list for another model with the option active engine mounts (I’d have to check for the C 63 S) offers the active mounts as a package with other options which are track focussed, ie firmer suspension, Race mode, and sports tyres (Pilot Sport Cup 2).
On that basis I would say that it would be logical for that model to use active (or dynamic) mounts to offer at least one stiffer than standard setting, as it’s packaged with “stiffer” options - and specifically the tyres are cited for track use. Whether the other mode is similar to standard or softer is anyone’s guess.
I can confirm that that car corners as flat as any car that I have ever driven, but that will be the cumulative result of lots of factors, with the mounts being one small part.
