Hello all - not much to update here. I found out the wiring harness is indeed the later one and non-biodegradable. As a result it is in very nice condition throughout with no obvious damage.
Looks like the car has a throttle body and potentially MAF fault. The car is with Terry at WG at the moment for this issue and a full check up (hoping to see what else needs doing in terms of bushes, any leaks etc.). We think the throttle body fix may also solve the rough idle issue as well as the throttle issue, will catch up with Terry in the week for thoughts. The cable to the throttle body is probably original so no doubt that's fried.
Off chance, I picked up a throttle body, MAF, ignition module and a few other bits and pieces out of an S500 coupe breaking nearby as they were practically dirt cheap but will most probably keep them for spares as they're original and have my TB repaired by rewire. By looking at the part numbers online the parts look like they suit the W124 500E. I also got the brake calipers off it. I wasn't sure if they are the same as they later E500 brakes (for 320mm discs) off the SL600 but looked very similar and for the price I got them for it was rude not to. Hope they fit, will get them checked against the SL600/later E500 units to see if they are the same by part number.
After deliberating what wheels I should buy I finally purchased a set of Lorinser RSK-5's in 9J front and 10J rears, 17", ET 44. Ultimately, looking at other brands of alloys (AMG/OZ/BBS) would stray the car from the Lorinser theme and I was keen to keep in as "Lorinser" as possible. I really like the look of these alloys and how they look on a W124 so I look a punt on them and bought them!
They come with bolts, spacers, centre caps and a virtually new set of Michelin sport tyres. The front tyres will however have to change as they are 255's, I think I will run a 225 or 235 on the front. I'll keep the spare 255's as another set for the rear (which may come in handy if I decide to fit the ASR defeat in). If I'm feeling flush I'll go for a fat rear tyre size (anyone know what a 500E can handle on the rear with a 10J?), I'd imagine 265, potentially 275. Anyway, here are the photos:
On a facelift Lorinser E500 also in silver:
I was also lucky enough to come across a set of original Hella W124 500E headlights off eBay. These are specific for the 500E and can't be bought as lenses alone (you can only purchase the entire headlight unit and that is £££ from MB). I will keep these as a spare set should anything happen to my set.
That's all for now folks - more to come once I collect the car
