kth286
Thanks very much Adam. The tyre tip too. I have Bridgestones on the back of my 124 Saloon.
On a whim I had it decatted ((rear)(this my 124 24V 300D)) and seeing as the middle box was getting tatty that was removed at the same time. Perhaps a mistake when looking for quiet cruising but boy does it sound "rorty" when pushed. The back box does rasp a bit as it tries to handle the straight through stuff when moving on. That can be attended to in time.
CHEERS
Are you refering to cat converter ?
If so, there may be some bad news around the corner for you and others that have performed a decat.
New MOT regs are due in Jan 2012 that require cars that originally had cats fitted, (even those cars prior to 1992) to have the cat fitted at test, or else a fail.
