1. There are seven (7) sorts of trimming resistor and they are used to adjust the timing of ignition (number of degrees in advance or after TDC). 024 545 0628 is 110 ohm: 024 545 0728 is 4,750 ohms
Pin outs to the engine are:-
(These are not identified on the Bosch modules but are on the Siemens)
1 – 3 not used
4 injectors 1 and 4
5 idle speed control valve
6 power supply to throttle position sensor TPS (potentiometer), and idle speed control
7 signal input from coolant temperature sensor
8 signal input from idle speed control
9 ground for TPs, idle speed control, air temperature sensor and coolant temperature sensor
10 ignition coil for cylinders 1 and 4 (ignition triggered by ECU breaking the ground connection of the primary winding)
11 ignition coil for cylinders 2 and 3
12 if used then for factory fitted alarm/immobiliser system
13 injectors 2 and 3
14 idle speed control valve
15 signal input from TPS
16 signal input from air temperature sensor
17 signal from idle/throttle switch
2. The base is metal and the circuit board is immersed in a silicone gel (has the consistency of jelly found in a meat pie). Arrows indicate the corresponding connections between the, now broken, wires from the circuit board on the left to the tabs on the right. The wires are very delicate as indeed are the connections indicating that very little current is used.
3. Most likely candidate for failure of ECU (no triggering for coil – cylinder 1 and 4). The connecting wire has become detached within the silicone and the area beneath shows a discoloured burn.
Note that the resistance on primary windings on the coils are 0.5 ohms and on the secondary winding 7,000 ohms. There should infinite resitance between primary and secondary and, indeed, with either and earth. The resistance of the loom between PMS and coils should be 0.3 ohms and again infinite resistance with earth. It might be a good idea to remove the engine connector with the PMS to check on the condition of the out pins on the PMS, it is the one area that shows quite a build up of white corrosion and may benefit from a rub down to fresh metal every decade or so
