The walk-through on that link is excellent (assuming it's correct). Even I would give it a go.I wouldn't be looking at the walnut rim. I would be looking at the throttle bodies and engine wiring loom! Rewiring the MAF Sensor in a W140 Mercedes Benz
Stunning. If only I had the Cahoonas
Weird the original owner didn't spec parktronic
ALL. mileage doesnt matter on these cars... low mileage cars do feel more special but these cars issues will all be related to its age.
I like the cut of yer jib !!! Personally I believe regular exercise as well as servicing is essential to maintain these machines! Any technical / service specialists on here to back this up?
Looks stunning! What are those centre caps on the alloys?
millo777 said:From what I've read the big issues related to the wiring loom on the early M120s were the ECUs and ETAs, bearing in mind there are 2 of each. Nothing that can't be re-built. Isn't it likely the wiring loom has been changed at 17 year old? certainly something to check before buying.
Whoever prepped the engine bay deserves a medal. It's almost guilting me into cleaning mine.
Even though I'm a massive fan of the w140 and the m120, the coupe's looks are a bit too challenging for me.
Head Gasket not so much but definately the wiring loom and especially electrical modules.
Your joking right... If the car has been stored in a garage there wont be a problem. Cabling is vacuum sealed when conductors are placed inside the insulator. Only when the insulator cracks via continuous temperature changes, vibration or a heavy fisted mechanic you will start to have problems with damp ingress . Age hardening/dissolving of plastic is hundreds of years
I had stored an old XJS V12 HE for 25 years, It hadn't been started for 14 of them... The wiring loom was that last of my worries, the brakes and old fuel were the biggest problems. Had all four corner reconditioned and then sold it to a guy who drove it to Italy (I thought he would never make it but he did).
Do you change the wiring in your house every 10/20 years?
No, he's not joking. MB had a problem with the material that the engine wiring looms were made from around that time where the outer sheathing of the cables degraded. There are many threads on here about the problem, just do a search.
You are correct -up to a point-- in that the degradation is temperature related- hence the main problems are in the engine compartment where underbonnet temperatures [ especially in a V12-- not a lot of room for air in there apart from a rather large engine!] accelerate the degradation. However the insulation was purposely designed to degrade quickly in landfill once the car was scrapped for environmental reasons so was predisposed to degrade just sitting around. I assume this was done at the manufacturing stage by either cutting down on the level of plasticiser to filler ratio or using a more volatile plasticizer?Ahh.. so if we park a W140 in the garage for 20 years and just let it sit there the sheathing will just degrade to the point the car won't start point taken though
am I correct in thinking that the only SL W129 cars free from the degredation issue would be the 103 3 litre and the 3 litre -24v version of the 104 motor?
I`ll show you a set of those sat,you can`t have them though lol
