nrg220
Yes indeed change it. Mine worked after I freed it but had it changed as its a dead in the water fault and you can't free it so a tow truck jobbie. Good luck
My guy used an esi emulator, so no steering lock.It will be a steering lock and column module...
Id expect a bill of circa £4-500.
Helen14a said:Exact same issue with my 2005 slk. Main dealer has quoted £700 to replace the ignition, plus a possible £400 for 2 new keys and has said I might need the steering lock replaced too, £230 if I have it done with the ignition £380 if I wait to see if the new ignition solves the steering lock issue, the car is only worth about £4K, is it worth it? Car only has 58,000 miles on the clock.....
It's a worry that yours failed with no warning making the repair more expensive. Was it the usual problem of the £15 motor failing inside the ESL ?
tifomb said:l WOULD NEVER BUY ANOTHER (newish) MB AGAIN ....
It was the motor originally but like I said the garage I gave it to (Polish guys) tried too many to program it (I have no idea why they were programming it since they only replaced the motor) and this 'locked' the board with 'error codes'. It was not be able to be programmed again.
They then bought an emulator (£60 ebay) but could not get this to work as again they couldn't program it (I have no idea why not).
So my ESL was useless.
I then had to either buy a new ESL (which MB don't sell as it's supply and fit only) or find one from a scrap car (which I did). I got the garage to take out the ignition barrel (EIS) and sent the ESL, EIS and 2 keys by post to a company that (1) put a new motor in the ESL and (2) virginised (blanked) the ESL from the other car and (3) took the programming from my EIS and copied it to the ESL and (4) put new batteries in the 2 keys since they didn't need programming.
Cost me about £480 for parts/repair not including the time I spent and travel/fuel, postage etc and the garage I gave it to was 11 miles from home, I made about 6 visits to it and many phone calls.
I had the car towed from home to the (Polish) garage because they said they can repair my ESL by (1) taking it out from the locked position and (2) putting a new motor in and (3) programming it, all at a cost of £250 an in 2 days. They took 3 weeks before they said "take the car away we can't repair it".
They cost me a lot of money and time.
My car was off the road (at home) for 3 months as all local garages were closed over xmas (it happened 5 days before) and MB dealers took a few weeks getting back with prices over the new year, the (Polish) guys took 3 weeks from end of Jan and the other company took 2 weeks to program (to receive my ESL etc, look at them, tell me I need another one, I then had to look for an ESL, send this to them, they programmed and sent back). But at least my ESL, EIS and 2 keys were all checked as fully working.
I WOULD NEVER BUY ANOTHER (newish) MB AGAIN ....
I don't think they knew it what they are doing.
Why not?![]()
Regarding your comment that you will never buy another Mercedes. Everyone have their own opinion.
