Just gone to start the car today and it just spun and spun, the cars been totally fine, used it all day yesterday with no problems.
Anyway managed to see the problem, the high pressure fuel pump at the front of the engine has a large leak from the bottom left head on the pump.
I know that a seal kit can be bought to repair the pump but would that cure the head leak?
The heads look like they are just metal to metal with no gasket so what exactly is leaking? Is it a bust 'O' ring inside that?
I also understand that the pumps can crack so until I take it off in the morning I can't be sure of that.
Also its not the plastic pipes that are leaking its def the head.
I'm wondering if getting a pre used one may be the way to go?
Any help would be great.
