Water in Tail Pipe exhaust missing
Screwdriver
I've owned my 1996 W124 E220 for the past 2 months. Since then I've changed the Air & Fuel filter, cleaned out the throttle body and run two bottles of Chevron Techron fuel additive through the lines.
I haven't seen water from the tailpipe on start up yet, common on healthy petrol 124s.
I plan to:
1) Change plugs
2) Inspect Coils
3) Pour "Seafoam" a crank cleaner through the intake piping
Could the lack of H2O be a sign of a bigger problem? Should I do more when the car goes for its 50,000 km tune up?
Thanks in advance!
Where do you park the car?
Dave!
I have it covered in an open parking spot. The ambient temperature outside, when checked, is pretty cool.
I should probably mention that my fuel efficiency is 7.5 kmpl in a mix of (50% horrendous traffic with AC / 50% highway)
I never get any condensation from the exhaust on mine unless it has been sat for several days. Then when it happens it's only for a few seconds.
If your mileage is fine which to me it does seem quite good then I wouldn't worry.
Dave!
