Water in W208 CLK cab
WayneS
Berkshire
w208 CLK 320 Cab
Hi all, first post here.
Just bought a w208 CLK320 and noticed some water inside. We picked this up before purchase and have agreement from dealer to fix.
The water soaks the carpet of the back footwells, mainly the near side so I am guessing that it is coming through the air feeds under the front seats.
The guys I bought the car from say they talked to Merc who got them to clear some drains.
We have only driven the car in dry conditions since but the carpets still get wet.
Can anyone point me in the direction of said drains (must be aircon as we have not been out in the rain).
Cheers
Wayne
Not 100% sure if this applied to 208 but worth checking out:
I believe there is an aircon drain pipe going down behind the drivers side centre console carpet bit.
If you remove the drivers carpet and release the centre console carpet a little you should just be able to see it - at least enough to check for leaks/pipe isnt loose.
Are you loosing any coolant? worth checking aswell? - interior heater pipes.
