Nice one, Ant, who doesn't like an upgraded horn!Van was collected today by local indie.
- MOT.
- Full service.
- Discs & pads all around.
- Upgraded horn.
- Wheel alinement.
- Full valet.
- MOT.
- Full service.
- Upgraded horn.
- Wheel alinement.
- Full valet.
Absolutely Toe. Existing horn is shameful. I’d rather have a minor collision than have to sound it.Nice one, Ant, who doesn't like an upgraded horn!![]()
Incidentally my indie has got a top of the range 119 Vito crew van. Cost over £50k. Same crappy horn as my poverty spec van. Sounds like Mrs Ants mobility scooter horn.![]()
Thanks for that Mikey. So that would be a straight replacement with no additional wiring required?http://www.stebel.it/stebel/products.asp?IDserie=6&uso=1&tipologia=auto
I used to fit these to my VW T4's. The standard horn on those was like a bee fart and VW also chose to mount it of all places in the nearside front wheel arch where it got all the road crud thrown over it. I used to extend the wiring up into the engine bay and mount the Nautilus on the slam panel.
Not sure on your Vito, but on the VeeDubs I always wired it in via a relay to be on the safe side. The wiring on Transporters was always a bit low budget.Thanks for that Mikey. So that would be a straight replacement with no additional wiring required?
BTW, Bee Fart is the perfect analogy.![]()
Share pictures of the rear coolant tank.
- New engine mounts
- new gearbox mount
- New alternator
- New thermostat
- New coolant tank at the rear of the engine (nightmare to fit)
Here's one fitted to a Sprinter.
wish i could. Klasse did it and they raised the car and showed me the back of the engine. looked like a really old tank filled with coolant and it was leaking. half the engine had to be taken apart. i didnt expect such thing in the engine itself, especially plastic.Share pictures of the rear coolant tank.
Brake pads arrived today from Rock Auto in Wisconcin USA. They took a mere 6 days from ordering so brilliant service from them.Ordered replacement rear brake pads for the taxi.
Gone with Powerstop Z16 Carbon ceramic pads from Rock Auto in the USA.
£57 delivered seems OK to me. If they are as good at keeping down the brake dust as the TRW front pads I'll be happy.
Didn't you change pads on a prior post?Brake pads arrived today from Rock Auto in Wisconcin USA. They took a mere 6 days from ordering so brilliant service from them.
Had to enlarge the hole slightly for the wear sensor to fit but apart from that they look fine.
I'll find out how good they are when I fit them tomorrow.
Perpetuating the thread drift a bitLOL. Sounds like the one in my wife's old Clio. About as strident as the one in Noddy's. car.
It was properly embarrassing, actually, when I forgot how shit it was and used in "in anger".
Luckily the Fiat 500 that replaced it is Italian and has a horn almost as powerful as the engine.
I swear it actually slows the car down.
That was the front pads, these are the rears.Didn't you change pads on a prior post?
How are these pads in comparison to OE? I've never tried anything apart from OE from Brembo and Textar, and OEM ones from MB (which have both Textar and Brembo stamped here). You suggested the bigger calipers and larger diameter brake rotors.
Keep update on the dust please , I find it a pain especially on inside of rim , I like to look in and see inside clean as well as outside.That was the front pads, these are the rears.
Haven't been out to really try them out for stopping power today, just bedded them in. The fitment was perfect apart from the wear sensor cut out in the pad being a fraction too small. Easily opened up with a file.
I chose these ceramic pads to reduce the amount off brake dust. OEM leave the wheels filthy after just a short run.
The OEM pads with the Mercedes logo on them were Jurid branded.
Where did I suggest bigger calipers and brake discs? It's not something I've ever recommended to my knowledge?
You must be confusing me with another member.![]()
I can recommend TRW low dust ceramic pads.Keep update on the dust please , I find it a pain especially on inside of rim , I like to look in and see inside clean as well as outside.
Cheers will be trying them on the cls.I can recommend TRW low dust ceramic pads.
Using them on the front and they are brilliant.
Got them through Autodoc for around £65.
